fired up the C42IBD. Loaded up filament and went through the adjustments. Took me a few tries to get used to dual extruders in slicer but figured it out. Extruders, Hex hotends and everything worked very well. Happy. going to bed.
you know what i use my dual for the most...
printing with another filament so that i don't have to change it out :-P
Using S3D, I just choose T1 as the tool to use, instead of T0
Anyone using the NEMA 17 version know how long a motor you can get away with? I have a stack of 47mm long body NEMA 17s and it looks like the MakerFarm ones from the printer kit are 45mm that I could probably switch out. Would either of these work with RobH's modified extruder body or should I grab some of the NEMA 14s that clough42 lists? I have vague memories of reading somewhere that 40mm may be the limit, but confirmation would be nice.
Regarding the flexible filament, I took sreid55's suggestion to print the 3mm body and bore it out for a 4mmOD/2mmID PTFE tube. I won't lie, there may have been some cursing and throwing of stuff while trying to get the tube rammed through the channel, but I finally got worked through once I stuck in some ABS filament bolster the tubing.
Since then, I haven't done anything large, but my small test prints using PolyFlex and ABS have turned out well.
I'm still getting some dribbling to the side, and the filament develops a pretty significant dent at the pinch between the hobbed bolt and idler. It printed just fine despite the dent.
Oh, none of that was a complaint, I've been nothing but happy with the Itty Bitty Double. Even as-is, the flexy stuff is printing really well, I just wanted to provide data.
Keep up the excellent work, Sir!
Your new biggest fan =D
oh just wait till you see whats next :-)
