Hard to say how good they really work! I think they help a bit to isolate it from what it sits on. I have made a bunch of vibration feet for various stuff. It's fun to design and make and they may actually work also.
Well, I throw in the towel on this. I have tried two scripts and neither works correctly. Then slic3r just make s a huge mess. It changes to the wrong temps after the first layer. It is massively under extruding etc. All of this is actually on my Flashforge Creator Pro. When I run it on the QIDI it is even worse.
I don't know what the issue is but I am far from getting anything to even come close to a real print.
Hey W, Here is a New Years present. I guess it's actually a re-gift cause I just found it on Thingiverse. No idea if it works or will crash your printer either, so I guess that makes it kind of a lame present...
http://www.thingiverse.com/thing:2005590
Happy New Year to all
New heat bar, heat sinks and fan set up from our friend JF. Went together very nicely.
[IMG]http://i58.photobucket.com/albums/g2...psvvuvm6s6.jpg[/IMG]
I've looked at those on his website, but haven't purchased them yet. I think they seem a much more elegant arrangement than the stock one. Should make keeping things accessible, aligned and stable much easier. I am most curious to learn how the hot ends behave vice the stock parts. Can you safely reach the higher temps needed for some materials now?
Here is a Benchy print. First print after a few calibration cubes. Not a great pic due to the light.
Still working on settings in S3D and always open to advice!
Haven't tried any higher settings yet. I am thinking to get some nylon and give it a go.
[IMG]http://i58.photobucket.com/albums/g2...psv9fecgyi.jpg[/IMG]
Hey everyone!
Before I start taking apart the extruder, I thought I'd ask a question I am sure is on the previous 381 pages! :-)
I have been doing fine with prints up until now. All of a sudden, I hear clicking which I assume is coming from the hobble gear skipping on the filament. The printer, while this was going on, was under-extruding. (I have seen this in the past with my other 3d printers during over-extrusion when it just can't push the filament out quickly enough.) I was able to extract the filament and run the extruder without filament. No clicking. When I put the filament back in and just try to extrude some into the air, I see it is under-extruding and clicking again.
Thoughts prior to a disassemble?
Thanks!
Update: I pulled the motor, heat sink, and fan off. They look fine. My guess is there is a clog further downstream.
