Using ABS Black filament, 3mm made by MG Chemicals, using makerfarm hobbed bolt, using fan from makerfarm, using springs from your kit. ive run into prints where i just stops feeding in middle of a print and when i check it , the hobbed bolt just ground down the filament,
steppers are not skipping
running 245 degrees on .4mm hotend, hexagon
