I see. The FFCP doesn't have that setting in the panel and the QIDI is running so can't check. Going to start another test on the FFCP and see how it goes.
Should force retraction be on or off? Seems to not make much difference I think ...
FFCP should have that setting. Qidi too.
You can try turning the force retraction between layers off, if it is a retraction problem just make it not retract. For every retraction there is an equal prime. That is why I said to do a -.4 extra restart. This tells it to do a 1.4mm retraction but only a 1mm reprime.
The reason I thought the negative restart was affecting small areas is that on one of those green monsters I did had an issue printing the lower teeth. They where small and it looked like it extruded only partial filament. I noticed on other parts that small areas with short extrusions were incomplete.
Ya the geniuses thought of that too, that's why there is a minimum travel for retraction. Just realized you are talking about 2 different models here. Settings like this are model specific. Just because your monster didn't like the negative restart doesn't mean it wont work on the barrel or whatever that is. It is important to focus on settings for one model or it gets confusing to everyone. You can't always make a catch all profile for every model. As nice as that would be it just doesn't happen.
I am getting closer but I cannot figure out what is causing the saggy look.
Any ideas?
I am thinking I am going to print a dual blower now I have to decide which.
[IMG]http://i72.photobucket.com/albums/i1...918_183150.jpg http://i72.photobucket.com/albums/i1...918_183126.jpg http://i72.photobucket.com/albums/i1...918_183058.jpg http://i72.photobucket.com/albums/i1...918_182924.jpg http://i72.photobucket.com/albums/i1...918_183047.jpg[/IMG]
Yea, I know it, the monster was just a side note. The barrel wasn't working at a restart of -.25 and with it a 0 it was still the same. I reset everything back to default and am seeing how it is going on the negative restart.
Upon checking the model, -.4 isn't going to do it. I am getting about 6mm distance of under extrusion from the starting point before the extrusion smooths out. It's either blobs or no plastic!
