It's still going to have a seam. The issue is it is extruding to much material when it starts that path.
Seems like there may be more going on, otherwise why not bulge on the inside too?
09-18-2016, 03:25 PM
jfkansas
Can randomize start/stop points. Possibly a little more retraction but don't go wild on it. 1.4 or 1.6 is good. I speed up retraction to 50mm/s.
09-18-2016, 03:35 PM
Talon 3D
Interesting.
Have you made the changes to your printer to be able to print the flexible filament?
I am still deciding on it for mine.
Quote:
Originally Posted by DaveB
Just noticed that MakerGeeks has a new NinjaFlex equivalent filament at $39.95/Kg. MG calls theirs "Maker Flex" and so far are listing it in 6 colors. Darn little info about it other than to say "Maker FlexFlexible filament is based on the exact same resin properties" as Ninjaflex.
09-18-2016, 03:40 PM
Syd_Khaos
Quote:
Originally Posted by Talon 3D
Interesting.
All you really need is a low-profile feed gear(some Qidi come with them), and some feed carriage parts meant for flexible filaments, and you can print those.
09-18-2016, 03:43 PM
wirlybird
Quote:
If I randomize I get blisters all over! The "seam" is ok because the barrel would actually have it but the bulge is the issue.
I will try the retraction. You really run that fast on retraction? That would be 3000mm/min. I know switch to "sec"!
09-18-2016, 03:48 PM
wirlybird
Do you think extruder temp to hot? I printed the same item in ABS and the seam is much different. The other settings were mainly the same.
09-18-2016, 04:09 PM
DaveB
Quote:
Outside Outline Direction?
09-18-2016, 04:17 PM
wirlybird
Do you mean outside-inside first setting? If so it doesn't make a difference.
09-18-2016, 04:24 PM
Talon 3D
I have the carriage parts DL'd I have not printed them yet. My QIDI is only a couple months old and supposedly came with the newest parts. Still cannot verify it though. LOL
Quote:
09-18-2016, 04:26 PM
wirlybird
So retraction settings and speed change are having no effect.
