Originally Posted by
jfkansas
Cause a lot saying that use Marlin firmware and it has that calibration stuff semi built in. So they mention it assuming that all firmware has that setting built in. Sailfish kind of does, but it isn't as "out there" as other firmwares.
What's wrong with calibrating on the fly with Extrusion multiplier? Even if you calculated a new number for filament adjustments to the Multiplier may still need to be made. So instead of adjusting in the .85-.9 range you would be adusting in the .98-1.03 range. The end result is the same.
