I'd definitely like to have those.
I wonder what would happen if one of the fixed wheels on top were replaced with an eccentric spacer, or both. seems then the tilt could be adjusted slightly if needed, perhaps on the order of half a mm ... only need to drill out the holes to take the eccentric spacer? I got my double extruder installed today, and checked with paper under them, seems both nozzles are very close to the same height off the glass .... but no print tests yet, still need to wire it all up.
I made a tilt plate for my i3v 12" will test soon, http://www.thingiverse.com/thing:664362/#files
C42 when you get ready to test the e3d itty bitty let me know ill order a second one and be your guinea pig
What scale are these in?, inches? mm?
Im running into jamming with the extruder, need to add more tension on the hobbed bolt
What filament and temperature? Are you using the MakerFarm hobbed bolt? What fan are you using to cool the hot ends? The one from Digi-key, or something else? s it actually grinding the filament? What springs are you using? On my extruder, with the springs I include in the kit, the motor skips long before the ABS filament strips.
