Originally Posted by
jstrack2
Anyway with all of this said I don't think that this issue is too big. Vibrations on the desk don't seem to really translate to vibrations at the resin when it is sandwiched between water and salt water (which is the reason for doing all of this). They are only generated by the temporary lowering then raising of the resin level. But these surface waves die after a couple seconds. So it is just an issue of making print times longer. Of course there may also be better ways to change the resin level or to have the surface waves energy dissipated faster that could help too. I will try doing a test later to see if the wall approach really helps things.
