I not sure but don't think so.
I have a Qidi Tech and CTC printer they both have identical Mighty 1280 based boards and both have Sailfish 7.7.
It's all the same. What I did is make a shoulder on the base of the pin that fits snugly in the bolt hole on the acrylic to hold the clip in place along with a tight fit on the two edges then the pin is a mm smaller so it fits easily in the bolt hole on the printer.
Btw, Smoothie is not very good as a lot of people are finally finding out (here is just one example but Google to find more http://forum.seemecnc.com/viewtopic.php?t=10151 ). It is really quirky and does have issues with Thermocouplers. Now, a DUE based board will serve such a project better since the board will work "Dan Newman's fork of RepRapFirmware already supports up to four MAX31855 thermocouple interface boards connected to the SPI pins of the expansion connector." It is an ARM based board so will be a better solution AND is fully opensource so you can mod to your heart's content.
You might have ugly wires coming out of the printer but I can guarantee you the machine will run circles around what it can do now if anyone wants to ditch that Mightyboard setup and switch over to gcode and PWM that works for everything.
Just got an email from BIQU. I'm not sure how to interpret this, but here is what I got:
"Hello David,
Our account has been Suspended yesterday, so sorry about this.
When we appeal it back we will e-mail you, thanks for your kindness supporting and understanding!
Hope you have a good day!
Sincerely
BIQU Team"
There ya go they fall into the 90% bracket, that I mentioned, where Amazon yanked them and apparently their account was suspended (in reality it is terminated). This means Amazon had a lot of complaints on them and their nozzles. There really isn't any other way to get an account terminated/suspended on Amazon. I bet you a dollar to a doughnut a lot of people never received their product and Amazon had to step in.
Amazon doesn't play around and it is damn near impossible to get a reversal from Amazon. I have seen it before but it is very rare.
They had 13 pages of items in their store. I doubt all of the complaints were regarding their nozzles, particularly as they would not be hitting the streets in the USA until September. I did get some PTFE tubing from them, and ended up returning it for a refund.
Here is an interesting printer...
https://www.kickstarter.com/projects...der-3d-printer
Exactly. Doesn't mean it was their nozzles it could have been something else they sell and if Amazon gets too many complaints, or inquiries as to where in the heck is my stuff I purchased, Amazon will make it right and will shut down the seller. I have seen this a lot of times with eBay sellers trying Amazon and failing miserably because a lot of stuff eBay, or even worse AliExpress, allows Amazon will clamp your privates down with a vise as they don't play and are not as lenient as the others.
