Originally Posted by
rcleav
PETG takes a little dial in time I will give you those settings when your ready. I use Esun filaments from Amazon.
I use AquaNet Purple can and spay a coating on the glass outside of the machine just before printing. It's thick enough to kinda look like the glass is frosted.
By the time the heated bed is hot it's dry. You know if you need another coat if you suddenly have trouble getting the print to stick. Usually can get a few prints per coating. After printing just let the glass cool off and the print will fall off. Don't forget you will need a z-axis shim to compensate for the glass thickness.
Available on thingiverse most flashforge z-axis shims will work on the Qidi Tech.
