So you need to activate the #define for the FRONT LEFT corner! And then see what the Topology report says. You should be able to get things very close to level if you correct the worst corner each time you run it. And when things are little be more flat, doing it with a 4x4 grid will help you see if you have high and/or low spots on the bed.
But your corners are not crazy. It should print well the way it is.
