Wirlybird been berry berry good to MG. Enjoy!
If you don't have a dry box ready for these, you may want to visit your local food store and pick up some 2.5Gal zip lock bags. Hefty makes some @ 12/box. A spool of filament will fit in nicely along with a bag or so of desiccant.
Here are some spacers to extend the Qidi's metal spindle length. Sometimes they are handy. Right now I've got two 5's and a 2.5 on each shaft.
http://www.thingiverse.com/thing:1530944
And if you've not run across them already, here is a customizable hub size adapter.
http://www.thingiverse.com/thing:735213 It works well to fill out that 17mm deep 85mm hole on the one side of the MG spools that is inevitably facing outward so it fits the 51mm Qidi shaft. This arrangement will allow the spool to fit on either way with no change but plugging in the adapter.
I don't have easy access to the rear of my Qidi, so I've found it easier to leave the metal spindle shaft (including 3 spacers) attached to the printer and just remove the short conic thingy on the end to mount a new spool.
I'm sure there are a million or so different ways to solve this, and I've probably totally missed the obvious solutions. Love to hear from folks with a perfect solution.
