Welcome, I've been using 123D for the last week or so. There are lot's of tut's on the web...
Thanks a ton, i was actually torn between open s cad, and 123D, while i have been useing Sketchup myself, it is ok for simple stuff, but doesnt quiet do what i want it to. Thanks again!
I have a Flashforge Dreamer and have had great results for the last few months. I have three questions:
1. Is there a definitive tutorial to printing with both extruders? I use Simplify3D.
2. I just started getting in cad drawing and have gotten started with TinkerCard. Any other suggestions for easy-to-use software for a relative beginner? This is my first only creation so far: https://www.tinkercad.com/things/5Rb...iphone-6-stand
3. I find that the Dreamer prints a little slow no matter how I adjust the settings. Any suggestions?
Thanks so much for the great input from this group, it's been very helpful.
Cheers,
Alex
Thanks for the in depth thread on the flashforge, i feel much better knowing that there are other people out there who run into some of the same issues i have had, and alot of what i have read, has made me alot more proficient with my printer. however i have run into an issue, i know i need to calibrate my printer, however i am not sure how to do this, i am running makerbot makerware (which recognizes my flashforge) for printing, and so far things have worked well for the most part, but i would like to start printing in better detail and need to calibrate it to do so. any help with this would be amazing!
I have this issue also. The fix that works for me is as follows:
1.) Close Replicator G and turn off printer.
2.) Open Replicator G.
3.) Turn on printer and wait for it to load up and sing it's song and such.
4.) Connect printer via USB and then press "Connect" button. If it worked your "pink" banner should turn green in Replicator.
Please let me know if this does or doesn't work for you. Best of luck to you.
I posted on the first, does anyone know how to calibrate the nozzels and extruders on the Flashforge Creator Pro?? i would rather not start tinkering blindly in my machine if i can help it.
