open to multiple filaments/filament mfg. large build volume, fairly decent layer resolution (tweaking to get there is fine just as long as its possible)
no DRM filament, easy maintenance, and acceptance of a wide variety of filaments! no ABS-only nonsense.
Quantity of prints, wifi and the ability to use different materials
High Resolution prints, low maintenance
auto bed leveling
affordaility and print size
after owning printer for 8 months the most important features are LCD controller and SD card compatible, good build volume (cross section > 8"x8"), and a heated build platform. Wont even consider buying a FDM printer without these
Being new to the field the thing that I am most looking for is the package of features for the least price. I want to get into the field on a budget while learning and then move up to something that is more capable and offers a larger build space.
The ability to reliably print using the entire build volume. Overall reliability as reported by the end users. Non-proprietary hardware and software. Build volume as a percentage of total machine size. Cost.
Very high resolution and the possibility to use filaments or resins from any manufacturer.
Build volume, drive train (V rails, etc), and community support.
Material quality, color, durability and detail.
I'm just getting into this.
1 Price
2 print size
3 Filaments supported
4 upgradability (to improve 2 or 3 above without buying a whole new printer)
Print resolution, build volume, reliability, metal construction, cost, number of hotends, speed, non proprietary filament, speed.
Multiple print materials, prosumer price range, warranty, balance between ease of use and open-ness.
Price, reliability, availability of replacement parts, speed, and customization
accuracy, surface finish. and price obviously.
Build size, affordability, model quality and speed.
Affordability and customization. DIY kits are a plus for me.
Large build platform, wide range of materials, Sturdy frame, DIY is also a plus for me.
Print area Size, print from sd card, quiet.
Q: What features are most important to you when shopping for a 3D printer?
A: Features listed by priority:
- 1) Filament Diameter
- 2) Material Handling; Need to have a setup to handle a variety of materials that are available in today's filament market.
- 3) Build Volume
- 4) Heated Bed
- 5) Open source hardware/firmware
- 6) Delta Style Printing
- 7) Spooling system
- 8) Convenience features; LED lighting, upgrades, 'Mod-Ability', printer size, ect...
Print quality
Multiiple print heads
Cost
Flexibility
Reliability, something that will work forever with few repairs needed and make consistently great parts.
Size, something large enough to build the parts I need now and will need in the furture.
The features that are most important when shipping for a 3D printer is if they have dual extruder, a heated bed to take part of more easily, build volume, and especially price.
- Heated bed
- Print speed
- Enclosure or partial enclosure
- Large build plate
- Multi-material compatibility
- Dual extruders = http://3dprintboard.com/images/icons/icon14.png
- USB/SD/Wifi
- Overall size
- Cable management
- Price $$$
1. Cost
2. Range of materials
3. Print quality
4. Size
Large build volume, easy to upgrade, large variety of materials that can be used and reliable. For a decent price.
Qualitity, Speed, Reliability and of course price
Price, reliability, simplicity, build size, resolution - in that order.
price, less maintenance, customer service, generic filament / multi filament, good build size.
Self-leveling or correcting bed. Ability to add multiple extruders. Reliability.
Zero or almost zero maintenance necessary
Build volume, speed, cooling, heated chamber or build plate, level of backlash, Z-axis resolution, quality of construction, high-temp hotend(s), software interface, and UI on the printer itself... I'm pretty picky :D
Price range unfortuately....
affordability, accessibility, a large print area (heated), chance to print in multible materials at once, speed.
I would look at the price first then build volume and quality of the print.
Build volume, quality, and speed.
upgrade-ability, company reputation and support, a community to help with problems.
