Its close enough for what your after :-)
There are five files in the link. Which do I download? The Zip file on the right?
I went through the Marlin folder in the link provided for the enhanced G29 and made (what I think) are the changes needed for my machine. Many of the changes were made already. Here is the link to the posts for the enhanced G29 thread.
My plan is to just open the Marlin ino in my Arduino, compile and load it into the Rumba. Hopefully it will work as I really am in unknown water here. I read all about trouble people are having with weird movements and am lucky I haven't had this yet. Fingers crossed!
In order to get my nozzle closer to the board I reduced my z axis offset to -2.8. This was before the enhanced version so hopefully it will carry over.
Thank god I found this topic.
I myself is working with the BI 2.5 from Boots Industry. The hardware is based on the rumba, and it's quite a pain to initiate the auto level bed. I have yet to make a sucessfull attempt.
That was my hope, that someone else would benefit from me asking so many questions. I think it is funny that in the beginning of this thread Sniffle made the comment that I would be figuring it out. It seems like I just kinda went along with the ride, he and others did the bulk of the work.
Still gotta get the enhanced firmware loaded. I am hesitant to pull the trigger!
So I uploaded the new firmware and things appear to be working with the one exception, and it is a biggie....
After homing the board's new zero point is actually 10mm or so above the glass. I used the offset numbers generated by following the zenmaster guide. What happening there?
When you input g1 z0 its 10mm above the glass?
yup. I am a few pages into the enhanced g code thread and haven't come across anything familiar. Gonna have to scour a bit deeper.
So far the only thing I may have to try is the m commands that save setting to the eeprom. Not sure what those actually do. Do they need to be run and inserted into the custom g codes in the slicers?
I keep waiting for you to get this finished up so I can start on it myself :O)
I haven't had the time to dig into it for myself yet, hope you get it all figured out.
disable epprom to start with , having epprom enabled overrides any changes in your abl procedure. also disable chitchat .
It was my understanding that these should be on for the abl to work? Not that I am doubting you too much (you know more than I) but if it was needed to be disabled, wouldn't the enhanced code have these features uncomented out?
Or, once it has run successfully I can re enable these features?
Eeprom is useless unless you are making all of you adjustments on the display. Since you are flashing firmware disable it... It will cause issues with abl.
Thats probably a part of your problem. Also make sure max endstops are disabled and software min endstops are disabled.
I
I disabled the chitchat and the eeprom lines by uncommenting them (//).
I am moving on to the endstop suggestions and am a bit confused. Pasted below is the section in the config.h file that I think is what you are talking about. Why I am concerned is that if I disable these lines below, does that disable the endstop switches? I have made the changes that I think you are suggesting.
PHP Code:
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
//#define ENDSTOPPULLUP_XMAX
//#define ENDSTOPPULLUP_YMAX
//#define ENDSTOPPULLUP_ZMAX
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
#define DISABLE_MAX_ENDSTOPS
#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 300
#define X_MIN_POS 0
#define Y_MAX_POS 298
#define Y_MIN_POS 0
#define Z_MAX_POS 300
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Gotta do some work at work ill edit this post in a few with tye code im talking about but you can look in the meantime.
I believe it is
#define Max_endstops
And
# define software_min_endstop
Both of those (and all of max endstops permutations) should be set to false.
But try reflashing after disabling eeprom and see if that fixed it... A lot of the time that fixes the problem. Just dont forget at the end of abl the nozel does drop to the 0 poaition it stays at the offset height until it it commanded to go to the 0 position
Nope. Did not fit my issue. After loading the new code and resetting the board it doesn't zero to the bed. I am still about 3.5mm above the bed. I called up the z-offset in the motion menu of the LCD and it is listed as 2.8mm. The value I have stored in the ABL section is -2.8. I am going to switch the sign to see what happens.
Nope. Changing the sign made it worse. The 2.8 is the correct offset. I double checked it and triple checked it. Somehow, after homing the axis my z0 point is 3.5mm or so above the glass.
Disclaimer, I am not 100% comfortable having the endstops disabled. I am a dunce sometimes and I hate to over extend the nozzle.
The only endstops that are disabled are the max endstops that are not hooked up to the machine. Having them enabled without them being hooked up can just cause issues...
Same with the min software endstop.
Is it just sitting above the bed after a g28 or g29? Or are you calling a g1 z0?
you already have the software min endstop disable .so your abl should work . if you Z offset is correct . (#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true)
So, to test I have added the EEPROM lines back in. There is a comment in the code that states the Z offset test has been removed. I wanna try and stick to the enhanced Marlin code as much as possible unless I can firm it works without this feature active. So far having it in or out has made no impact to my initial problem (Z-Axix height).
I have attached the config.h file again is you want to take a look to see what I am using. When I used these offset numbers in the firmware Colin supplied it worked fine. Now I get the weird z height after running the G28 command. I haven't checked a G29. I will do that shortly.
Sniffle, after I run the G28 command I will issue a G1 Z0 and the nozzle is well above the bed.
PHP Code:
// #define COREXY
#endif
#endif
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MIN_ENDSTOPS
#endif
#define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
//============================= Bed Auto Leveling ===========================
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line)
#define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#ifdef ENABLE_AUTO_BED_LEVELING
// There are 2 different ways to pick the X and Y locations to probe:
// - "grid" mode
// Probe every point in a rectangular grid
// You must specify the rectangle, and the density of sample points
// This mode is preferred because there are more measurements.
// It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive
// - "3-point" mode
// Probe 3 arbitrary points on the bed (that aren't colinear)
// You must specify the X & Y coordinates of all 3 points
#define AUTO_BED_LEVELING_GRID
// with AUTO_BED_LEVELING_GRID, the bed is sampled in a
// AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid
// and least squares solution is calculated
// Note: this feature occupies 10'206 byte
#ifdef AUTO_BED_LEVELING_GRID
// set the rectangle in which to probe
#define LEFT_PROBE_BED_POSITION 30
#define RIGHT_PROBE_BED_POSITION 275
#define BACK_PROBE_BED_POSITION 275
#define FRONT_PROBE_BED_POSITION 20
// set the max number of grid points per dimension
// The G29 command defaults to 3 if nothing is specified. But setting the number of probed
// points higher is very useful when getting a Bed Topology Report (G29 n 5 T)
#define AUTO_BED_LEVELING_GRID_POINTS 5
// Uncomment one of the following four lines so the Bed Topology Report can produce a map
// that relates accurately to your bed orientation.
#define ORIGIN_FRONT_LEFT
//#define ORIGIN_BACK_LEFT
//#define ORIGIN_FRONT_RIGHT
//#define ORIGIN_BACK_RIGHT
#else // not AUTO_BED_LEVELING_GRID
// with no grid, just probe 3 arbitrary points. A simple cross-product
// is used to esimate the plane of the print bed
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#endif // AUTO_BED_LEVELING_GRID
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
#define X_PROBE_OFFSET_FROM_EXTRUDER 21.2
#define Y_PROBE_OFFSET_FROM_EXTRUDER 1.8
#define Z_PROBE_OFFSET_FROM_EXTRUDER -2.8
#define Z_RAISE_BEFORE_HOMING 5 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 4000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 3 //How much the extruder will be raised when traveling from between next probing points
//#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell
//#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
//If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk
//The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it.
// You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile.
#define PROBE_SERVO_DEACTIVATION_DELAY 300
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled
// - If stepper drivers timeout, it will need X and Y homing again before Z homing
// - Position the probe in a defined XY point before Z Homing when homing all axis (G28)
// - Block Z homing only when the probe is outside bed area.
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
#endif
#endif // ENABLE_AUTO_BED_LEVELING
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
// For deltabots this means top and center of the Cartesian print volume.
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
//#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing.
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 50, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 4000, 838.5} // customized for MakerFarm i3v 10"
#define DEFAULT_MAX_FEEDRATE {250, 250, 2, 22} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1000,1000,5,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 15.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
//=============================Additional Features===========================
// Custom M code points
#define CUSTOM_M_CODES
#ifdef CUSTOM_M_CODES
#define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851
#define Z_PROBE_OFFSET_RANGE_MIN -15
#define Z_PROBE_OFFSET_RANGE_MAX -5
#endif
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS //removed to test z offset
//to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
// please keep turned on if you can.
#define EEPROM_CHITCHAT //removed to test z offset
// Preheat Constant
#define PLA_PREHEAT_HOTEND_TEMP 180
#define PLA_PREHEAT_HPB_TEMP 70
#define PLA_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255
#define ABS_PREHEAT_HOTEND_TEMP 230
#define ABS_PREHEAT_HPB_TEMP 100
#define ABS_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255
i have similar issues before. i noticed that after a firmware update i need to run a G28 , G28 X0 Y0 , and a G29 . First . if i dont do this my nozzle also stay high when starting a print .
but in my Case the printer doest do the abl procedure after g28 if i dont do this first after a firmware update. i havent figure it out whats the cause of this .
I did a G28 command and looked at the location. Still above the bed. I then followed up with a G29 command and after probing the 9 spots I issued a G1 Z0 command and the nozzle did drop to the glass. What is up with that? The G29 command seems to work fine but not the homing funciton. It doesn't matter if I hit the home button in pronterface or issue a G28 command. Both end with the nozzle not zeroing out. It is like it is not calculating the offset?
Weird, So I just watched the G28 command work paying attention to the LCD display. The machine homes X and then Y. After that it drops the probe and zeros the Z. All the while the display reads the Z axis to be 0.00. Once the home has been found the z axis starts to move up and the display says 10.00. This makes sense as the nozzle is moving up 10mm to clear the probe before raising.
The probe then moves up and then the display changes to 2.8! This is the z-offset stored in the memory. This is when the offset is factored into the behavior correct? It almost seems like the G29 is working as it should but the problem is in the G28 command line. Kinda like the offset is being added twice?
homing is the process where the machine finds its zero points. so it should read zero because until it actually finds the endstops positions in space it doesnt know where it is.
once the Z probe hits the bed, it raises(per what you want to happen), then retracts the probe and sets it height to 2.8 which is your offset.
is the height it is off the bed after you do a G1 Z0 the height you tell it to raise before retracting the probe?
Where is the z raise height before probe retract called out? When I issue a G28 command the x and y home then move to the middle where the z homes. Display reads zero. As soon as it finds zero the axis moves up, display reads 10. Once there the probe retracts and then the display changes to reflect the new offset adjusted height. which should be 12.8.
To answer your question, it is not. When I issue a G1 Z0 command the the Z axis moves down to what it thinks is 0 but is in fact is still 2.8mm above the bed. From my observation it adds the offset to its current position but should be subtracting it.
ok, i thought you had flashed the firmware version to gain that feature and had... my mistake.
i'm at a loss on this one... the important thing though is that it goes tot he correct height after g29, because if you have ABL setup your not going to g28 and print your going to g28, then g29 then print. If you are successfully dropping to the glass after a g29, then it should be working to get you a print... not promising but it should. I never have checked after a G28 if my offset is correct its always been after a G28 and g29 because that's the process my printer goes through every time before a print
I'm sure that it will work, just doesn't seem complete.
Where in the firmware is the g28 command programmed? I would like to see f I can figure out what is going on with the g28.
marlinmain.cpp i would assume, but i'm not sure
I am not having any luck reading that code. I think I understand it but get to points I really do not have a clue. What I am looking for is the part in the instructions that say what to do when a G28 command is issued. I want to see what is going on in a step by step fashion. After the probe finds the home the display reads 0 (As is it in fact finding 0). Well, the probe is finding 0, the nozzle should be finding 2.8 (My offset). In my mind, It should not be reading zero but rather 2.8.
As soon as it finds this zero height it switches to 10mm and the z moves up, then adds the offset value. This makes perfect sense. as it is at 10mm plus the offset. When then, when I issue a G1 Z0 does the nozzle not go to the bed? It mathematically adds up to me but doesn't compute.
I know it really shouldn't make a difference but it does to me. I still want to be able to manually level the bed from time to time without having all the complexity of adding and subtracting numbers. I just want to hit Z0 and have the board go to Z0.
I tried to message Roxy, is there anyone else who worked on that code or is it Roxy's baby?
I sent this to you earlier as a private message, but others here might be interested in its content:
Quote:
Re: Help with enhanced ABL
http://3dprintboard.com/images/tf_id...quote_icon.png Originally Posted by tsteever
The big question I have is which version of firmware is the best to use? Tight now I just got it from the first link in the thread. I am assuming that as people correct things that the link is changed to reflect the changes.
For historical reasons, that main thread will probably always exist. But there is talk of breaking it up into 10 or 12 different smaller threads for the various subjects in it. With that said... For you the most important thread is this one:
http://3dprintboard.com/showthread.p...s-enhancements
Even if you don't have a MakerFarm, this is the right thread to use. It uses a very current fork of the Marlin firmware and has most of the enhancements added to it. If you take this thread, and cross your Configuration.h settings over to it, most likely it will just fire up and work. But if it doesn't, if you still have that Z offset issue... Take a look at that thread starting at this post:
http://3dprintboard.com/showthread.p...ll=1#post43108
Right now, a new main branch of the Marlin firmware showed up with nothing but bug fixes. I need to cross all the enhancements over to it and use that as a starting point. But I don't have time to do that right now. And in fact, what we really need to do is get all the enhancements pushed back (and up) into the main branches of the tree.
Thanks! I think the most confusing in all this has been the info I find all over the place on this. I can't keep it all straight! My Printer with enhanced firmware seems to work, just not the G28. I guess I could always run a G29 command after it but sometimes I am only printing a very small part and don't need the G29. Oh well, got some reading to do!
Looking forward to following the thread that Roxy linked to. It can be found here. Looks like a good place that i should have found before all this!
Anyways, previously I had been reading the ABL and Enhanced Firmware thread in the firmware section and I came to this post. I am going to try and implement this tweak into my code to see if that helps. Basically it is adding another value to the G28 command which is what I thought may be missing. Hopefully it will work and Roxy has a chance to get the firmware sorted and streamlined. I think my confusion came from the so many different versions floating around. Would be nice to have a sticky "look here" thread.
The more I think about it, the behavior of the G28 with Auto Bed Leveling is not a bug. The purpose of the G28 is to Home the axis. It does that. At the very end of the G29 the code compensates for the Z_PROBE_OFFSET. It would be very straight forward to make the G28 do that also.
Found this post from Abu in the other thread and it seems to fix the issue. Not sure if it is a band aid or not but I can get the nozzle on the bed after a g28 now.
Pasted from here...
Do a G28, then a G1 Z0. Find out at what distance above the bed the nozzle stops. Let's call that number X.
Look for this section in Marlin_main:
PHP Code:
if(code_seen(axis_codes[Z_AXIS])) {
if(code_value_long() != 0) {
current_position[Z_AXIS]=code_value()+add_homing[2];
if((home_all_axis) || (code_seen(axis_codes[Z_AXIS]))) {
current_position[Z_AXIS] += zprobe_zoffset; //Add Z_Probe offset (the distance is negative)
#endif
Change the "+= zprobe_zoffset;" to "+= zprobe_zoffset+X;" inputting the number you found earlier for X. On my printer, it was 4.
Yes, this looks correct. This should get the G28 and the G29 synchronized in where they think the nozzle is relative to the bed. One small caution: If the bed is tilted at a noticeable angle, the nozzle will be at a different height than the probe because the probe is offset from the nozzle. The G29 corrects this 'error'. The G28 does not have the bed angle information and it can't do the more accurate correction.
Good to know! I'd really only be doing the solo G28 command on small prints that wouldn't need the ABL (Thin wall calibrations, etc...). I look forward to the dynamic build envelope settings being implemented if possible. Have the printer probe only the areas included in the Skirt would be a valuable addition to the feature. For now though it does appear to be working. This is with the Erik firmware not the beckdac firmware. I will see if I can't move these settings over to that as well.
What should be my next step? I know that there are some wondering/waiting to see if it was working. Should I just post my marlin folder in a zip?
marlin firmware is an ever evolving piece of software, with bug fixes and features being added all the time...
colin's firmware is like a snapshot in time, in the time since he made that copy of the firmware, many, many bugs have been fixed and features have been added not all of which will effect you or others but marlin is ever evolving into better and stronger code with features being added and refined daily
I'm not sure what I think about the dynamic build envelope. I actually wrote a piece of C code to process the GCode and set the parameters. But I think we all agree it would be best to just have one standard script to do this that everybody uses. The big reason I'm not sure what to think about this topic is this:
Unless you have big imperfections in a few locations on your print bed, aren't you better off measuring the whole thing where you can get more accurate numbers that are spread out? Suppose you are only printing something with a 1" square foot print. Can you accurately measure a bunch of points withing that area to set the bed angle? Or would you be better off going way out to the edges to measure your points so you can set the bed level correction matrix more accurately?
That I don't know. For the small stuff I have just been turning off the ABL and just using G28 in my custom code. I need to get the BeckDac working and my fear was the dynamic ABL stuff might cause troubles if I wasn't using the slic3r part.
Can I just load this firmware and ignore the dynamic ABL stuff and assume that it will work?
