S3d uses the script tab under process. If you have two process then you need two end codes.
I have end codes for each process already but only one of the hotends turns off
Due you have two M104's?
M104 S0 ; turn off extruder
M104 S1; turn off extruder
Don't you add a T0 or T1 to the M104 commands to specify what tool the command applies to?
