Originally Posted by
usarmyaircav
Kevin, Not sure if this is the same issue, but reading more your config settings, I got home last night, and did the estep calibration, which worked fine. Went to put in the amount and found that I have to fix my firmware to be writeable, so decided to just wait and print, cause I really wanted to print something. I decided to use cura, so followed your settings and got the gcode, loaded it into pronterface, and started the job. I could see filament oozing out some so figured this should be great. bed heated up and job started, but when it was doing the perimeter, the flow out was terribly erratic, and then stopped. I stopped the job, re-fed the filament tried again. same thing. Went back to Slic3r .99, same thing. reset all my esteps, and anything that I thought was too low but got the same thing. If I extrude into the air filament comes out, but doing a print job little to nothing. Could the nozzle need to be cleaned like you mentioned above, or is it possible that the nozzle is too close to the bed? I had the bed level just right, but, when I tried to print last, it seemed to be touching. I will check that tonight. I really need to get a modified endstop setup.
