Just in case you are unaware, there is a ton of information on this and more at rcgroups.com ;)
This is picture of most of what I have Now:
I think this is considered to be a 500 size, since it is about 500mm between front and rear motor, on other side ?
(and I think the design is called Spyda-500)
The motor and power wiring-harness pictured is assembled and ready to be installed.
I printed all the white plastic parts ! ;)
Attachment 7800
Click pic for larger view:
Very nice! I take it you have a lot of room to fly? My property has a ton of trees thus I stay with the 250 size.
I found out that the Sony camera Is a CCD type. ;)
Found a good mounting case for it at thingiverse also. ;)
Great! You did get the cable to change the settings with it, right?
If you are asking about the USB cable that goes to the Ardupilot-controller, then Yes .
I've not powered it up and tried that yet though .
Testing the controller will be one of the next things I will do.
I've been working on the GPS antenna and PCB Mount today.
That mount is another thing I printed, that I forgot to put in picture.
No, I'm talking about changing the settings on the CCD camera. I haven't seen one yet that I'm happy with the stock settings. Unfortunately, every camera seems to have it's own proprietary cable for changing settings so you have to make sure you have the cable needed to change settings for your particular camera.
