Repeated heat cycles will destroy regular glass regardless of how it's attached to the bed.
I always clean with acetone between prints. For printing ABS I use kapton tape on the glass with a little bit of ABS slurry. If I'm not using tape I use hairspray, I haven't had any luck with ABS slurry on plain glass.
Hairspray works great, sometimes too great--I've had it rip chunks of glass off the bed when removing a part, which is why I went back to using kapton tape on glass.
Temperature doesn't matter, it's temperature differential--if one side of the glass is hotter than the other. It doesn't take more than 30-50C difference to cause glass to crack.
Not saying it will happen, but it might and it will ruin a print. Not worth the risk IMO.
There's also the transfer of heat from the bed to the top of the glass plate which is MUCH better and more even with thermal glass. Regular glass is a poor conductor of heat, which is why it cracks more easily (creates a greater differential).
