Two very easy ways to sense low filament:
1) Weight. Have a scale that beeps when you hit a certain minimum weight. Since you already know the base weight of the holder and spool, a low weight threshold is easy to calculate.
2) A hall sensor on the spool measuring rotation of the spool vs the linear travel of the filament (another wheel with a hall sensor). When the ratio hits a certain level, you about how much filament is left on the spool.
How loud is it? Will I hear it on the other side of the house with the bedroom door closed?
