I want to buy a CNC plywood laser cutter some day.
The $450. CTC is a Very Good printer,
with a couple of modifications needed.
Such as : wire-guide-bracket on top of extruder assembly
and stiffeners on bed-plate-platform
Both can be downloaded from thingiverse and printed.
Note: The wire-guide is a 'Must have', or thermocouple wires will brake.
(so, make it one of first things you print )
platform stiffeners are not necessary but make it much more stable
Click picture of Guide for larger view:
Attachment 7406
Note: there are other versions of this guide but this is the best one
http://s18.postimg.org/kapqngae1/Sim...screenshot.gif
Here is a screenshot of the program. Where is variable speed? Is it what I surrounded in blue rectangle or is there another setting?
Thank you.
the 'variable' speed is applied by having multiple processes for a particular print.
But like I said it automatically adjusts speed according to the complexity of the print.
click the 'prepare to print' button and the resulting coloured sliced model shows you the different speeds by colour variation.
The platform stiffener and wire guide my flashforge creator x actually comes with. Only thing i had to do to it was add active cooling on the print area.
