Geoff, aardvark, Roxy...thank you for your help!
Hi all,
my apologies for not replying earlier ( busy).
Here's a hand drawn wiring diagram.
It may not be exact, as I may have cut the hot lead between the IEC & switch or after the fuse - whatever.
I also left the original rear rocker in the circuit, so if it initially doesn't work - the rear switch has to be on also.
Running a job right now & don't feel like flipping it over.
You essentially have to put the switch in the hot (line) somewhere & connect the lamp tab to a neutral.
DO NOT use a 12V switch on the 120/220VAC lines!
You'll have to ohm out the switch, as no two lighted switches are the same.
Use at your own risk - I'm not responsible for disasters! :confused:Attachment 2713
Cool 😊Thank you!
