Thanks. and you still can.. if your willing to dismantle :)
Staring to wire things up.
the instructions are confusing.
"Heat Bed Relay
The 10” i3v heat bed requires more power then ramps can handle. Because of this your
kit has shipped with a heat bed relay we are going to connect the heat bed relay to D8 and
connect the heat bed to the relay.
DO NOT CONNECT YOUR 10” HEAT BED TO D8, THIS WILL DAMAGE YOUR
RAMPS AND VOID YOUR WARRANTY."
Why say plug into D8 and then say dont..
So that MARLIN can control the heat bed relay, the relay coil is wired to RAMPS D8. The high current wiring for the heat bed goes through just the relay. This may help - Clarifying i3/i3v heat bed and heat bed relay wiring
The relay goes to D8 and the other side of the relay goes to power supply and heat bed.
I misread it.
I thought at the end it said.. dont connect the relay
Can I flash the Rambo with the USB connection to the comp, after i wire it all up to the the power supply and motors or do i need to do it before.
