Quote:
1. I use the Flashforge Creator Pro as a starting template and then once I have some settings I like I do a Save As... and name it "Qidi - Some Description".
I suggest watching their video tutorials: https://www.youtube.com/playlist?lis...O7wODJpQBVf-Ss
2. Add the following code to the startup script tab. This will do the line on the front of the build plate.
Left Extruder:
Right Extruder:Code:; **** Replicator 2X start.gcode ****
M73 P0 ; Enable build progress
G162 X Y F3000 ; Home XY maximum
G161 Z F1200 ; Home Z minimum
G92 Z-5 ; Set Z to -5
G1 Z0 ; Move Z to 0
G161 Z F100 ; Home Z slowly
M132 X Y Z A B ; Recall home offsets
M135 T0 ; Load right extruder offsets
G1 X-110 Y-75 Z30 F9000 ; Move to wait position off table
G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating
M126 S[fan_speed_pwm] ; Set fan speed
M140 S[bed0_temperature] T0 ; Heat buildplate
M134 T0 ; Stabilize bed temperature
M104 S[extruder1_temperature] T1 ; Heat left extruder
M133 T1 ; Stabilize left extruder temperature
G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs
G92 A0 B0 ; Zero extruders
M135 T1 ; Load left extruder offsets
G1 X-100 Y-65 F9000 ; Move to front left corner of bed
G1 Z0.3 F6000 ; Move down to purge
G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed
G1 X100 Y-65 F180 ; Wait for ooze
G1 X110 Y-65 F5000 ; Fast wipe
G1 Z1 F100 ; Lift
G92 A0 B0 ; zero extruders
M73 P1 ;@body (notify GPX body has started)
; **** end of start.gcode ****
Both Extruders:Code:; **** Replicator 2X start.gcode ****
G1 Z0 ; Move Z to 0
M104 S[extruder0_temperature] T0 ; Heat right extruder
M133 T0 ; Stabilize extruder temperature
G1 X100 Y-70 F9000 ; Move to front right corner of bed
G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed
G1 X-100 Y-70 F180 ; Wait for ooze
G1 X-110 Y-70 F5000 ; Fast wipe
G1 Z0.5 F100 ; Lift
3. I don't know. I've seen mine do something like that, but I haven't worried about it.Code:; **** Replicator 2X start.gcode ****
G1 Z0 ; Move Z to 0
M133 T0 ; Stabilize right extruder temperature
G1 Z0.5 F100 ; Lift
G1 Z1 F100 ; Lift
Where or how do i navigate to the startup script tab on mac? Sorry, totally lost....new to this.
