Originally Posted by
Syd_Khaos
High humidity can affect it rather a bit from what I've seen.
The bigger issue I have though is plate adhesion, I get alot more curling and lifting the higher the humidity goes. I have to print EVERYTHING in ABS on a raft...everything! And even then it will pull up or curl at times.
I did a print this afternoon of Victoria Crater (where we landed Opportunity on Mars), and the front left corner peeled up about 1.5mm. This is a 100mm x 100mm square, with 2mm offset raft with thicklayers enabled.
I'm not gonna be happy till my incase humidity is single digit....and preferably the lower end.
