Tightening belts on new model of creator pro?
So I'm having an issue where when I print at what sounds like fairly reasonable speeds(60/80 for a .2 res print, for some reason 50/70 at the same res is fine) I'm getting a slip or two in the y axis. One of the belts seems like it might be a little loose and I'd like to try tightening it. However, I've got a newer model without set screws. Anybody know how to tighten the belts on those models? I'm a total noob when it comes to mechanical things, so any help is appreciated. :)
