Originally Posted by
Roxy
Some rotations of a given servo are more sensitive to twitching than others. I designed my probe with that in mind. But I went a step further. I made it so there was a 'Stop' that the probe could be rotated against. By setting the number of rotational degrees for the servo to go to a few degrees more than it actually can go it gets pressed against the stop. In theory... once you tell it to go past the stop, you would think it should just stop.
That is not the case. Some angles have a twitch and some do not. More is not better. If you use this approach, find the specific angle where you go past the travel limit, but it doesn't twitch!
Also, I made it so that the when my switch gets pressed, it is slightly offset from where the probe rotates up above it. That causes the probe leg to press gently against the stop as each point is probed.
