US colorFabb - New types of filament at Printedsolid.com
Hello, We are the US reseller for colorFabb filaments and are focused on getting new innovative materials into the US market.
Check us out at printedsolid.com. You can check out this material for cheap with our sample packs. http://www.printedsolid.com/product-...t-sample-pack/
colorFabb makes four unique filaments with a major focus on quality control. All filament (with the exception of the woodfill) is guaranteed to a tolerance of +/-0.05mm, but is typically even tighter. The 3mm is nominally 2.85mm for optimal Bowden performance. All materials are focused on environmentally sustainable materials.
Soft Touch PLA/PHA is a PLA that is modified with PHA to improve it's toughness and elongation to break. Similar to PLA, it prints at 175-210, prints on the same base (i.e. blue tape or similar), has low warping, and requires no heated build plate. It is available in numerous Pantone colors, which means that (for example) every spool of traffic red is exactly the same color no matter when you order it. This material is ideal for anyone who likes printing in PLA, but want to get a little bit closer to the flexibility of ABS while still maintaining the higher strength and low warp of PLA. Check out some info on my blog here. http://www.printedsolid.com/testing-...fabb-filament/
XT amorphous transparent copolymer is a biopolymer based material. It is 'extra tough' and 'extra transparent'. Flexibility is very good, comparable to or more so than ABS. Layer adhesion is also amazing. When printed in single layers, clarity is impressive. It prints at a little higher temperature than PLA (210-240C), but can still be printed on an unheated build plate with minimal warpage. Bridging is great. In addition, it can be vapor polished with acetone, although the result is slightly different than with ABS. More info here: http://www.printedsolid.com/vapor-po...-colorfabb-xt/
Finally, they are about to release (and are taking preorders for) two new woodfilled material. Woodfill fine in 1.75mm and 3mm and woodfill coarse in 3mm only. This material is a pine wood particle filled PLA. It is about 30% filled. The resulting print material maintains some nice flexibility relative to some other filled materials. The fine can be printed on standard 0.4mm nozzles. The coarse comes with a drill to open the nozzle to 0.8mm. This material gives some amazing bridging performance due to the fill. Check out my testing here. http://www.printedsolid.com/testing-...d-xt-and-more/
Thanks for your time and happy printing!
