Originally Posted by
VidJunky
Welcome to the forum. Just a couple of questions before I offer any advice. What slicer are you using? When you say burnt and curling up, at about what layer does this start to happen? Are you having issues with adhesion at all?Anyway, based on the information you've shared, I would say you're correct in thinking that you're running too hot. But I don't think you went far enough in your reduction. Try printing at the lowest temp shown on your PLA roll, which is 190 for the brands I use. I mean this should end any over temp or melty appearance you are seeing. As for the curl, it would really help if you could post a screenshot of what you're seeing. What layer height are you running? If the temp takes care of the brunt look, maybe try running a thicker layer if you're seeing too much squish. .2 makes a decent print and I believe is the standard in many slicer programs for PLA and .4 nozzles. If you're not running .2 try printing at .2 or even .25 see if that eliminates the squish. Once you establish a baseline for your printer you can start to play with the settings a bit more to develop a range of settings that work best for your environment, the type of prints you're printing, and the brand or type of filament you're using. I'll use myself as an example, I use Creality PLA fairly consistently. I know black works best for me at 190 and green at 195 to 200 depending on infill, and perimeter/wall settings.
