Thick TPU Parts at 100% in-fill, warping, is this just a 'material tension' issue.
I have been printing for about 18 months, so far only PLA and TPU. Part of what I do for a living is mount GoPro cameras on various vechicles for a small TV crew I work for.
One of those tasks involved putting cameras on cars that are designed to crash into one-another (we call them, here in NZ, "StockCars"). Given that nature of that motorsport, I cannot get away with standard GoPro mounts. So I have designed some clamps and arms that keep my cameras in place. They are printed in 95a TPU.
Given the nature of the sport, and how I have to mount the clamps using through-bolts, I cannot use anything other than a 100% infill. The parts simply get crushed at anything under around 80% infill. And if they take an impact, then that last crush resistance is super important.
One issue I am having, is what seems to be a problem more with the behaviour of the material itself, than a build-plate adhesion issue. Once the material reaches a certain height (normally around 15-20 mm) I can often see the part starting to warp. I have tried the following;
1. Print speeds, slower, faster
2. Build plate(s) PEI, textured, glass
3. Build plate temp 0, 15, 30, 60 (none of it seemed to matter - on any of the plate materials I tried) (also differing hot end temps from 200 to 250c - same results across all temps)
4. Retraction settings (I have no idea how this one was supposed to affect a warping issue, but it was suggested, so I tried it).
5. Tape/glue/anything-that-is-sticky on the build plate (no difference)
6. Different brands of TPU (local NZ supplier's TPU, CrealityTPU, ESun TPU etc etc)
7. Enclosure (with and without all the various combinations above)
Am I right in thinking that this might just be an inner-tension issue with heating/cooling across the thick cross-section of the material itself? I mean, short of allowing it to cool completely between every single layer, I'm not sure there's anything that can be done. I can print thinner TPU parts no issue at all.
And just getting back to the bed adhesion thing, I have managed to pick the entire weight of the printer up off the bench whilst trying to lift these parts off the plate - they are stuck - which makes me think I am fighting a "material tension" issue.
Am I an idiot, or is this likely more a material properties problem than an 'adhesion' problem?
Thanks!
