Multiple Base Layers Flared
Hello,I have these 2 puzzle pieces that I'm using to test settings and clearances for another project that will use these puzzle pieces. I think I've got the clearances pretty close, but the bottoms of both pieces are wider than the tops. The pieces should be 40 mm x 25 mm and they're within the accuracy range at the top of the print. However, the base was flared out so they don't "mate" together properly. I thought that this was a result of elephant's foot and adjusted the horizontal expansion accordingly (0.22 mm). The initial layer seems to be about right, but the next 8 layers are all wider, and then the top 15 are all accurate.https://i.imgur.com/hGpQ92W.jpeghttps://i.imgur.com/IUuY1Vu.jpeghttps://i.imgur.com/fXQK8Or.png
I am using the Longer L5K Pro
