The Beginner Guide to Buying a Vacuum Cleaner 2020
No modern home can be without a good vacuum cleaner, especially in the age of ubiquitous home appliances, and even automation of those devices. Vacuum cleaners have revolutionized the way of housekeeping, freeing up the labor and time once spent struggling with dust, cobwebs, and pet hair around the house. Owning a vacuum cleaner will be your timesaver, and lifesaver if you are a pet owner.
With thousands of vacuum cleaner brands introducing their latest products, laypeople like yourself can find looking for The https://imgur.com/3lIrYI9.gif Best Vacuum Cleaners in the market daunting. If you are confused as to where to even start with all the mystifying technical terms and vacuum cleaner specs, let our guide accompany you on your next shopping trip.
Understanding that the best vacuum cleaner is one that best suits your needs, this guide introduces you to the basic terms and puts the spotlight on what really matters when considering a new vacuum cleaner.
Airflow and Suction Power
Airflow and suction power are the primary specifications to check out when buying a new vacuum cleaner. Airflow, in cubic feet per minute, tells you how fast a vacuum can pick up dust and debris. Suction power, in inches, tells you how strong a vacuum can be.
You might not want a higher-powered vacuum, considering the flooring material in your home. While a vacuum cleaner may work perfectly fine with hardwood floors, high airflow power can overly agitate your delicate Turkish carpet and can even rip off the threads from your faux-fur rug.
If you have to deal with multiple surfaces and various types of flooring, a vacuum cleaner with different power settings will give you the flexibility you need. Note, however, that the vacuum's performance also depends on the suction heads and attachments, because they directly deliver the airflow and suction power to the surface.
Going Cordless?
Traditional vacuum cleaners come with a notoriously long cord to provide the power they need to operate over a large area. Corded vacuum cleaners thus have higher airflow, suction power and capacity than cordless vacuums, enabling a variety of attachments and tools.
But the cord comes with its set of problems, from trip hazards to the fact that the cord can only get so long. The corded vacuum is generally heavy and bulky, so expect a decent workout trying to move the vacuum along and fit it in tight storage space.
Cordless is the technology of the future, especially when best vacuum cleaner brands https://imgur.com/BrJkexc.gif decided to pull the plug on their corded models. Battery-operated handheld appliances, cordless vacuum cleaners waste no time plugging and unplugging in-between uses.
Their inherent lightweight and compact design allows for high maneuverability when working in tight corners. Battery life might be of concern if you need more than 30 minutes on medium power mode, but the trade-off would be minimal if you don’t do deep cleansing often.
Bagless vs. Bagged
Whatever gets sucked in the vacuum ends up in the dust canister in the bagless vacuum and in a dust bag in the bagged vacuum. Most vacuum models on the market are now bagless, as the washable canister is the more cost-effective and environment-friendly option. Bagged models, while requiring frequent replacement of dust bags, neatly contain fine particles, preventing spills and harmful exposures, perfect for allergy sufferers and those who are too lazy to empty the canister.
Final Words
There you go, the beginner guide to buy a vacuum cleaner! Remember, the https://imgur.com/v4izu9H.gif best vacuum cleaners in the world are the ones serving your needs the best. Stick to our guide the next time you go shopping for a new dust sucker and break no sweat doing the housekeeping!
