Start G-Code
Hi
I have a Ender 3 Pro and I use the Prusa Slic3r.
I've recently upgraded to the Micro Swiss Direct Drive kit and it includes some G-Code that I need to run at the start to adjust the x, y origins.
However, this causes the head to run along the X axis right where my clips are for holding my glass, plus I like the Prusa start up G-Code as it runs two lines up the left on the Y axis to get the filament going.
Is there anyone who could help me incorporate the two start up codes, so i adjust the x, y but also run my usual Prusa start sequence?
The Micro Swiss G-code is:
G28 ; home all axes
G92 X-5.0 Y-10.0 ; set home offsets
G1 X0 Y0 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X160 E15 F600 ; prime nozzle
G1 X180 F5000 ; quick wipe
And my current Prusa start-up is:
G90 ; use absolute coordinates
M83 ; extruder relative mode
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
G28 ; home all
G1 Z2 F240
G1 X2 Y10 F3000
G1 Z0.28 F240
G92 E0.0
G1 Y190 E15.0 F1500.0 ; intro line
G1 X2.3 F5000
G1 Y10 E30 F1200.0 ; intro line
G92 E0.0
Thanks
Adam
I have the same DD. I did not change start gcode, but instead adjusted bltouch mount offset in the firmware. What solution fixed the issue for you?
