New Printrbot Plus connection woes
Hi everyone,
I purchased and assembled a New Printrbot and haven't been able to get it to connect, move, print. It is run by a Raspberry Pi and a Printerboard rev D. When I turn on the power supply nothing lights up at all. If I run a usb to the micro port on the Pi it lights up and comes alive with an active power led, and occasional blinking act led, the wifi thumb installed also flashes. If I connect y-ed off wires from the voltage supply as directed led 2 lights up on the printerboard. I have installed the serial driver and ran as administrator. I am not getting any found new hardware prompt. When I attempt to connect to it through com3 using repetier .95 it says connected somehow, but will never act as though it is. It cannot be moved manually or heat the bed or extruder although the software makes it seem like it will.
I am at a loss and would love to get this thing up and running after all the work and money I put into it. Any suggestions would be greatly appreciated.
