Originally Posted by
ragod222
I'm having so much trouble with the CubePro. Since purchasing it last spring I've had issues using online based 3D Systems rendering options to be compatible with this machine. I was told it was due to the larger than normal nozzle diameter. I work in a school, and specifically chose this machine to support printing designs for a large number of students, since it boasts a high speed print. This is in fact great about it.
Unfortunately I can't even get the supports to actually print consistently. In some areas it will render supports that work as they should, but usually it simply builds a small pillar that can't support more than a 2mm squared area. I've adjusted nearly every setting available before slicing with no changes to specific areas that should clearly have supports.
Another concern is that I can't get it to fill some areas of certain designs. I think that if I choose the highest quality print and choose the smallest mm fill size there shouldn't be any holes in my final print, especially if other areas render properly within the same file.
Does anyone have any suggestions for how I can figure out what seem to be slicer flaws for the CubePro?
Please help!
