1 Attachment(s)
Can See Modeling Detail in Final Print
In parts I have designed you can see the modeling detail in the final print, ie: the individual circles, rectangles, lines, etc that make up the structure as a whole.
I am using Fusion 360 for design, Simply 3D, and a Flashforge printer with ABS.
Below is an example image which is a screenshot from Simply 3D. It is a simple structure that started with two circles with a line drawn between them to close them up. And then fillet on all of the edges. The final print shows the lines just like you see in the image. I would like to see straight lines, or similar, and not the original drawing artifacts.
I'm new to the design world so I am sure there is something I am missing here...
Thanks for any help in advance!
Attachment 9121
