What 3D printer should I buy and where?
I want to 3d print furniture from:
- metal (bronze and steel)
- wood (not plywood, but actual wood with no additives in it)
- cement (actually soil, clay, Portland cement mix)
What is / are the best printers that can accommodate my needs.
- easy to learn
- produce high quality finishes
- ideally can use all the above materials, if it's possible (otherwise please advise separately)
- and of course, the least expensive version for the quality
I intend to work from a small home based workshop, it should not be an industrial version...
Thank you.
