Originally Posted by
JohnnyV
What material are you using and what is your bed temperature?
Here are the settings I use for S3D and a flashforge knock off (Powerspec 3D Pro).
Layers: 2
Offset from Part: 2.00
Separation Distance: 0.20
Raft Infill: 70%
I get pretty good results with Inland ABS. Rafts can be difficult to removed. I use a razor blade to help shave it off. I'm also considering bumping the separation distance up a bit to 0.25 to make it easier.
You might also consider using a glue stick or ABS slurry instead of a raft. Some people prefer that.
