Octoprint with FFCreator Pro is this going to work ?
Hello there, trying to setup my RaspberryPi2 with Octapri (octaprint) with my FFCPro with GPX plugin, the printer has connection with the server no problems, but the GCode Viewer or progress of the job or print time info doesn't work at all, is this normal ? Is the FFCPro just partially supported or there is something wrong with my setup ?
Also if I drop an .gcode file to sdcard through web interface the file is transferred to printer but after that is disconnecting my printer from the server :/ and I need to click connect again
Thanks
