First try at printing at 0.5 layer height
So I've finally got round to sorting out the profiles on s3d v3.0.
And everything is workling properly now.
I've got individual profiles for left and right extruders that work properly.
My flashforge creator has an 0.4 mm nozzle on the left extruder and a 0.5 mm on the right.
Don't ask why just, seemed like a good idea at the time.
So I've got a biggish bracket that needs to be strong. Figured I'd use the new s3d solid infill and 0.5mm nozzle and layer height.
Looking good so far.
Using cheap ebay pla and so far no sign of warp. Mind you I've probably got an accumulated layer of gluestick a mm thick on the bed :-)
I set the nozzle width to 0.5 (if you select auto it wants to go to 0.6) and layer height to 0.5.
Likewise I have lefty set at 0.4 width (auto wants 0.5)
I printed a similiar but slightly smaller bracket yesterday with the left head at 0.4 layer height. And despite the usual: 'you've exceeded a 1.2 ratio thingimygig' message it printed perfectly and is every bit as strong as I wanted it to be.
Currently printing at 60mm/s - but looks and sounds like she'd happily print faster.
I decided to go for right head as it had no filament in and hadn't been used for quite some time and was just faster to load it than unload and reload lefty as I'm not quite sure there's enough filament left on the left reel.
Also want to make sure it's working as I have had issues with it in the past.
So far -36% - so good :-)
More later.
