Extruder motor won't drive while printing
So I have a LDM printer setup with a Rambo 1.3 board running Marlin firmware and Repetier host. I essentially built and setup the printer from the bones of an older, obsolete printer and I have everything setup except the extruder motor will not drive while it is printing. The printer does not have a hot end or heated bed, and I think somewhere in the firmware or settings there is an error not allowing it to print due to the thermal settings, but that is just my best guess. I can run the extruder manually using the manual control in Repetier, so I know everything is connected at least.
So far I have:
Disabled the temp sensors in Marlin by setting #define TEMP_SENSOR_0 0 for all thermistor inputs.
-Edit: I used a resistor connected to the thermistor to fool the printer into thinking the 'hot end' is at 189.4 C (hoping to fool it into thinking it is PLA), making the 0 a 2 in the above code
Set the minimum temp for the prevent dangerous extrude to 0 #define #define EXTRUDE_MINTEMP 0
-Edit: This was set to 180
Set the "Default Extruder Temperature" to 0 in the print settings in Repetier
I have tried to connect the thermistor to the board, but for some reason when it is connected the motors for all the axes don't receive any signal.
-Edit: This was also set to 180.
Edit: It does run the retract and extra length on restart settings while trying to print. It just doesn't run the extruder motor while it is executing a print job
Thank you,
-Nick
