3 Attachment(s)
First Print
Well, I plucked up courage to run a test print expecting the worst. I didn't treat the glass bed with anything, so got some warping, also some flattening around the base. The build was half of a 20mm Test Cube. The dimensions of the finished product was 20.06mm x 20.16mm and the thickness of the hexgonal filler walls was .48mm, so a little tweaking may be required.
3mm PLA was used with a .4mm Hexagon head, nozzle temp of 210 and a bed temp of 65 and aprint speed of 50mm /s.
For a first attempt I was pretty happy with the results, let the tweaking begin.
Attachment 5598Attachment 5599
