I noticed that
when I watch the hotend temp on the LCD display.. it jumps wildly.. its set to 245 and it might jump down to 239 and then to 250 within 1 second.
I noticed that
I doubt that is physically possible for the nozzle to actually swing that much that fast with the heater we have. I would hazard a guess of poor thermistor contact with the block.
I have a E3D v6 the thermistor is screwed down
I would perform PID tuning/calibration.
Be sure you have the correct thermistor selected for the E3D (1 I belive) and then run the following command from Pronterface:
This will run the self PID tuning and you will have three values in the Pronterface console to plug back into Marlin on the appropriate lines.Quote:
M303 E0 S200 C8
See this site for a more in depth description or watch Tom's guide here (Highly recommended).
swirvbox
E3d thermistor is 5
And you should pid auto tune the temp you plan to print at which is the S value
You are correct. It is 5. Derp. I print at anywhere between 185 and 270. Not on the i3v however. I have not had the hexagon up that high yet. I am still not as confident with that hotend as I am with my E3D.
I have already had to reseat the heater to the heat break once already with the Hexagon. What a mess it made as it puked plastic from the top of the heat block.
swirvbox
Yeah i had that happen too... I am saving my hexagon for my kossel i am building its a nice light all metal hotend.
