1 Attachment(s)
Print warping at corners, please advise
Printer: Airwolf HD2x (Dual Extruder)
Material: ABS 2.88mm
Problem:
I am having an issue with a simple 1" cube print. In the first 3/8" of the print, 3 out of 4 corners are showing warpage (see attached image). My best guess is that the second extruder head is adding too much heat to the print. But, I would like to get some expert feedback from the forum. Thank you.
http://3dprintboard.com/attachment.p...tid=5278&stc=1
For slicing the STL I used Astroprint. Settings below:
Print settings:
Slicing Software |
Cura |
Layer Height |
0.1 mm |
First Layer Height |
0.27 mm |
Shell Thickness |
1.5 mm |
Solid Top |
Yes |
Solid Bottom |
Yes |
Fill Density |
35% |
Print Speed |
20 mm/s |
Infill Speed |
30 mm/s |
Inner Shell Speed |
30 mm/s |
Outer Shell Speed |
20 mm/s |
Travel Speed |
125 mm/s |
First Layer Speed |
10 mm/s |
Number of Skirt Lines |
3 |
Skirt Gap |
5 mm |
Skirt Minimal Length |
150 mm |
Number of Brim Lines |
5 |
Support |
None |
Support Type |
Lines |
Support Angle |
70 deg |
Platform Adhesion |
None |
Raft Margin |
5 mm |
Raft Line Spacing |
1 mm |
Raft Base Thickness |
0.3 mm |
Raft Base Line Width |
0.7 mm |
Raft Interface Thickness |
0.2 mm |
Raft Interface Line Width |
0.2 mm |
Raft Air Gap |
0.4 mm |
Raft Surface Layers |
2 |
Support Fill Rate |
35% |
Support X/Y Distance |
0.7 mm |
Support Z Distance |
0.15 mm |
Support For Dual Extrusion |
Both |
Wipe Tower Volume |
25 mm3 |
Filament Diameter |
2.85 mm |
Filament Flow |
95% |
Print Temperature |
240 °C |
Print Bed Temperature |
105 °C |
Enable Fan |
Yes |
Minimum Fan Speed |
0% |
Maximum Fan Speed |
0% |
Fan Full Height |
0 mm |
Minimum Layer Cooling Time |
15 secs |
Minimum Cooling Feedrate |
2 mm/s |
Enable Retraction |
Yes |
Retraction Amount |
5 mm |
Retraction Speed |
50 mm/2 |
Retraction Minimal Travel |
1.5 mm |
Retraction Minimal Extrusion |
0.02 mm |
Retraction Combing |
Yes |
Retraction Hop |
0.25 mm |
Retraction Dual Amount |
16.5 mm |
Spiral Vase (Joris) |
No |
Wipe Tower |
No |
Ooze Shield |
No |
Cooling Head Lift |
No |
