Flashforge Creator right extruder oozing filament
Ok, so I'm a total noob when it comes to 3D printing. Purchased the Flashforge Creator, set it up and leveled the print bed as per instructions. Loaded both the filament spools as instructed. Than began printing the test object located on the SD card. It is a small traffic cone. I can't think of anything more useless, but it is what it is. I was not sure wether it would print the object from the left extruder or the right, but after the print began it became clear it was printing from the left one, which is loaded with white ABS filament. That's fine. Printed a nice little useless cone perfectly. However, the right extruder which was loaded with red ABS, oozed the whole time ending up with a 1/2" hard red blob on the end of it when the print was finished. My initial thought was that the right extruder was too hot, however, it was heated to the default 230 Deg... same as the left one. So maybe temp is out of the picture??? i was using the ABS supplied with the unit. Any help is appreciated!!!
Radarlarry
