Biqu B1 SE Plus Extruder gear slipping
I'm brand new to printing and got a Biqu B1 SE Plus as an early Christmas present.
I haven't been able to do a single print as the extruder gear keeps slipping a couple of minutes into a print. If I manually push filament through, it works but I don't want to be doing that over the course of a 2-hour print.
I've tried everything recommended elsewhere;
- Changed printing temps, speed and z-axis offset.
- Tried different filaments.
- Changed the PTFE Tube.
- Cleaned the extruder gear and re-tightened.
- Pre pulled filament from the roll to reduce strain on the feeding gear.
- Cleaned and changed nozzles.
- Completely replaced hotend.
- Checked, loosened and tightened the feeding lever.
- Checked the tension spring.
- Changed plugs and power cables.
I'm completely lost as to what is causing it, I've had the thing for a week and I haven't gotten a single print over 3 layers, and that one is awful.
Any further ideas or something I'm blatantly missing?
