Ender 3 V2 - Continuous Nozzle Clogging
I recently bought a used Ender 3 V2 printer and the first two simple and short prints went relatively smoothly. However, when I attempted a 7-hour print consisting of three parts, one element got cut off due to a clogged nozzle. I reprinted that element and it worked fine, but now I'm trying to print a part that takes around 10 hours, and each time the nozzle gets clogged after about 1-2 hours. I've tried three times already, and I even replaced the nozzle, but the issue persists.I'm using filament that came vacuum-sealed with a moisture-resistant bag, which arrived yesterday.
I'm using the filament :
PLA Colorfil Filament - Material Characteristics
Manufacturer: Colorfil
Base Material: PLA
Filament Diameter: 1.75mm
Tolerance: ± 0.05mm
Net Weight: 1kg
Printing Temperature: from 190ºC to 230ºC
Bed Temperature: from 0ºC to 60ºC
Bed Temperature: set the nozzle temperature to 200 degrees and the bed to 60 degrees. I'm using the standard settings in Cura.Please,
I'm looking for advice on what to do next.
