Originally Posted by
warkmal
Though that thread is for having the left extruder print 34mm to the left. It sounded like you were just off 1-2mm? If so, there's a X-offset setting in the eeprom which you can adjust (it's what defines the position of "home" when your start gcode executes an M132). But some start gcode (MakerBot Desktop for example) recalls the offset and then makes it useless by stomping on it with a G92 that defines the position to a fixed location, so to adjust it you need to change the start gcode not to do that.
