1 Attachment(s)
Any thoughts on the Weistek WT2 All Metal 3D Printer
I'm concidering buying a Weistek WT2 and wanted to see if anyone had any experience with the WT2. I've Googled it and really don't see much on it? I was also wondering if the same printer could be sold under any other names. I see that the Weistek WT150 received good feedback on Amazon.
I found one that sold on eBay with these specs.
Weistek WT2 3D printer has parameters and build volume similar to UP! and Afinia 3D printers. It also has the same type of heated build plate as UP1 3D Printers.
- Voltage: 110V-220V
- Gross Power: 360W
- Dimensions(L*W*H): 300 mm x 330 mm x 400 mm
- Weight: 22lb / 10kg
- Layer thickness: 0.1mm - 0.3mm
- Build Envelope(W x D x H): 150*150*130mm
- Nozzel: 0.4mm
- interface: USB
http://3dprintboard.com/attachment.p...tid=5431&stc=1
