Originally Posted by
JohnA136
It is clicking because it can not push out the filament fast enough. Either the temp of the extruder is too low or the filament diameter is wrong in your slicer setting. I would suggest raising the extruder temp 5 degrees and if that does not help, re-slice with a LARGER diameter setting for your filament, maybe try .02mm larger as a start. Si if you measure the filament and set is at 1.73mm, try 1.75? Did you measure your filament diameter in several spots and put that in your slicer setting?
